API RP574 - structural minimum thickness for large diameter piping
Have anyone an extended table about structural minimum thickness for piping?
Whath criteria do you suggest to use for an 88" blowdown pipe?
RE: API RP574 - structural minimum thickness for large diameter piping
Supposedly the minimum D/t ratio guideline of 100 could be applied as it is a dimensionless number, but 88" is really large.
What are you blowing down?
