Pipe Load & valve design
ASME B16.34 & API 6D ask to consider pipe load for valve design but didn't specify how to use them. If customer has given bending stress as a design condition how to use it for design of single piece and 2/3 piece valve body? Any illustration will be highly helpful.
Cheers!
Cheers!
RE: Pipe Load & valve design
In the formula the d3 is approximate the PCD
