Minimum distance of column from basement wall
Hello Engineers,
Is there any provision or rule of minimum distance of column outline from basement wall?Is there any problem if column touched basement wall surface. Please have a look in uploaded these picture and leave a comment.
Information:
Basement wall thickness 10''
Basement wall total height 9'
Height from round level 6'
Below ground level 3'
Thank you very much.
Images:
Information:
Images:
RIFAT
RE: Minimum distance of column from basement wall
BA
RIFAT
http://imgur.com/a/L7MPQ
RIFAT
1) easy forming and;
2) a single pouring operation
A pilaster gives you both. If there's a chance that both the wall and column formwork will be present concurrently, I'd give yourself 12". Otherwise, 6" should do.
The only other issue I could see is the proximity of the foundation elements for the columns to the foundation elements for the wall violating the minimum spacing for the geotechnical requirements.
RIFAT
