Small Diameter Flexible Hydraulic Hose
I'm looking for a fairly flexible hydraulic hose that has an outside diameter of no more than .25" (6.4mm) and can withstand up to 1000psig (includes FOS).  The hose would be subjected to cyclic loading of essentially 0psig to its operating pressure every second or so.  I might be able to lower my operating pressure if I found something close.
Any leads?  I've just started looking but have had no luck as of yet.
-Mike
RE: Small Diameter Flexible Hydraulic Hose
Check Aeroquip 246 or Stratoflex silicon reinforced hoses.
boo1,
A couple good leads, thanks.
-Mike
