pwht of joint
pwht of joint
pwht of joint
i have a column in which joint configuration is groove of 36 mm and fillet of size 10 mm is overlapping on it. should i go for pwht?
RE: pwht of joint
First, what is the column material? Carbon steel? What code of structural steel construction are you following? Have you qualified a WPS for this weld joint configuration and base material?
RE: pwht of joint
My column is of material SA516 GR. 70 ,and construction code is ASME SEC. 8 DIV 1 .
i have approved wps also.
Concern is my DCBB fillet weld is fouling on circ-seam of column. Circ-seam have thikness 36 and fillet have thikness 10mm
RE: pwht of joint
IF you have a weld process specification, then your WPS tells you the requirements for PWHT.
Follow it. Asking the internet for a PWHT requirement is not prudent.
RE: pwht of joint
Follow the rules of UCS-56 in ASME Section VIII, Div 1 for PWHT guidance.
RE: pwht of joint
Not specified in code.
RE: pwht of joint
swatik. Read again UCS-56
r6155
RE: pwht of joint
swatik patel, I'd venture to say nobody knows exactly what you are talking about, but if you have a circ seam in a cylinder that has been previously welded and heat treated (or not) per Code, then to later add a 10 mm filet on top of it is not likely to need PWHT.
Mike
RE: pwht of joint
swatik. In your case(36mm) preheat is required at a minimum of 95ºC during welding.
See Table UCS-56-1 in full
r6155
RE: pwht of joint
Also see UW-40(f).
