Privacy Warning:
Privacy Warning:
Privacy Warning:
I have just started to see the warning below in a spread sheet that I'm creating. This is the first time I've seen this and as far as I know it doesn't stop me from saving the file or reopening and editing. Anyone know what this is about?
Clyde Hancock
Design & analysis of electric motors and generators
https://www.motorconsultants.com/home.html
RE: Privacy Warning:
I'll drink to that...
Dik
I once found a key combination in Word that called up past edits in a document I received from a client. You should read the things the client said that were then edited out!
BUGGAR,
Make sure you turn off Track Changes.
JHG
