Get curve attribute with PCL function
I would like get curve attributes (curve ID, points ID and coordinates) with a PCL function.
I would like write a text file with a format like .bdf or .dat not with mesh elements but geomtric elements like curve, point, surface.
for example
In the patran_2012.2_doc_pcl_reference I have seen db_get_curve_id, but when I use it I cannot get the ID of the curve
For the points ID and coordinates I have not found a function.
Who can help me please ?
Best regards
for example
CODE -->
CURVE ID PtA PtB SURFACE ID PtA PtB PtC PtD POINT ID X Y Z etc ....
CODE -->
INTEGER entity_id(1), status, label status = db_get_curve_id( label, entity_id(1) )
Best regards
