Calculate flow through control valve
I need your help here if you don't mind.....
Can I know how much flow is passing through a control valve if I knew
Cv of the valve.
Type of the fluid.
Diff of the pressure.
Diff of the Temperature.
Opening of the valve
What the equation should I use ???
Do you have a small program can do that for me???
Do you know a web site regarding this???
Thanks for your cooperation,,,,,,,,,,,
Abdulla N Ateya
RE: Calculate flow through control valve
Joerd
Jordan has one on site. that you can download. It offers globe style, sliding gate and low flow sizing for contro valves and regulators as well as both flow and Cv sizing.
