hollowcore production (slipforming or extrusion)
Hello everyone
I would like to know if someone can explain me the differenece between slipforming and extrusion production of precast hollowcore slabs.
Thank You
RE: hollowcore production (slipforming or extrusion)
Both methods are typically the same, except slip forming will use a normal slump concrete and extruded will typically use a dry slump.
Hi.  is there any to tell me what's the advantages of using hollow core concrete slab? compare to reinforced concrete slab? thanks..
I am looking for some feedback on the pro's/con's of using hollowcore floor slabs in combination with poured concrete form walls for residential basement construction. Any comments?
Please start a new thread for your question.
