PRIMA PLATINO 3000 PRC best cutting parameters
Hi, We bought a secondhand 2003 paltino HS Primapower co2 laser. I would thank you if you answer the questions below:
1 - can you give me the best cutting parameters of Feed and gas pressure and power ...? it seems that the parameters that software gives us are not ok
2 - the consumption of laser gases seems to be so high. we consume every 50lit He cylinders with 200 bar just in 80 hours of laser use, Is it normal or abnormal?
thanks for your paying attention
RE: PRIMA PLATINO 3000 PRC best cutting parameters
I checked and there is no leakage throw the way up to laser source
