CS SSAW ASTM A53 Gr.B SCH STD SERVICE PIPES DAMAGE REPAIRS
We are having some CS ASTM A53 Gr.B SCHSTD SSAW service pipes with dents on the body of the pipes happened during the fall of stacks and also a few pipes having out-of roundness towards the ends. Please advise me the standard and accepted practices for the repair of dents as well as the out-of roundness of the pipes with respect to the standards?Is it allowed to carry out repairs for the same? if yes, as per which standard?
REGARDS,
G.SRIRAM.
Dream,Dream,Dream Dream transforms in to thoughts.And thoughts result in action
RE: CS SSAW ASTM A53 Gr.B SCH STD SERVICE PIPES DAMAGE REPAIRS
Third, you could look at API 579 FFS for dented areas for application.
Could you please clarify me on the ovality of the same size of pipes too?
We almost have a variation of 30mm-40mm between the maximum OD and minimum OD of the pipe. How to rectify the same?
Appreciate your valuable response.
Thank you.
REGARDS,
G.SRIRAM.
