Does pcc layer must be isolated????
Hello engineers we all know that RCC footings must be isolated with not less than 2 layers of liquid bitumen but my question is the pcc 10cm layer under the rcc should be isolated or no ?
The engineers divided into 2 opinions
First opinion says that the bitumen weaks the texture between pcc and the rcc and the surface of the pcc must be roughed
Second opinion says the pcc must be isolated with bitumen and this doesn't decrease the texture between pcc and rcc and the pcc surface must be smoothed
What is the right thing between these 2 opinions
And actually I poured the pcc few days ago and the surface is roughed and i m confused do i isolate or not
Thank you and soory to prolong
RE: Does pcc layer must be isolated????
It is not necessary to bond the blinding layer to the RCC.
