Hydraulic valve query
Hello all,
I'm converting a 110v SDS drill to hydraulic operation for use underwater.
I have chosen an OMM 8 hyd motor and coupled it to the existing commutator shaft.
The spec is max continuous 16 lpm flowrate with a max working pressure of 140b
I now require a means of controlling the rotation speed of the chuck, by way of altering the hyd flow through the motor. I know there are needle valves available but I would like to utilise something with a roller or push button action that would be easier for my diver to use.
Any ideas?
Many thanks,
Steve Lucas
Any ideas?
Many thanks,
Steve Lucas
RE: Hydraulic valve query
http://www.csunitec.com/drills/hammer-drills-air-h...
Ted
http://internationalhydraulicsus.com/brand-fc51-12...
Ted
A 1/4 turn ball valve is unlikely to give you much in the way of fine flow control.
Do you know what the tool is going to be paired with by way of a hydraulic supply? In my corner of the business, we work with a mixture of constant flow, constant pressure and "variable everything - whether you want it that way or not" plants - all of which place their own demands on the controls downstream.
Have you asked the divers how they feel about manhandling a tool that's stuck on the end of a pair of half inch hoses - one of them pressurised to 140 bar?
Keep a careful eye on the state of your fluid. You may get quite a bit of seawater ingress through the shaft seal of the motor.
A.
Your link to www.csunitec.com/drills/hammer-drills-air-h... displays the tool that I would choose if money were no barrier.
However, a similar product here in England costs over £2000, a not inconsiderable sum you will agree.
The picture shows the drill being controlled by a 'trigger'; Now, whether this is a speed/flow controller or not, I don't know but a mechanism like that is what i'm after.
Kind regards,
Steve
The intended hydraulic supply is via an engine driven hydraulic powerpack, stationed on the bank with approx 20m of 3/8" hoses supplying the tool. Our divers have been working with UHP water to a pressure of 2000b so are familiar with high(ish) pressures. The hoses are covered in layflat protection thus minimising danger through hose rupture.
The drill body will be sealed as much as possible to avoid water ingress but I will certainly be monitoring the condition of the hydraulic oil returning to tank.
Best regards,
Steve
Merry Christmas to you all!!
Kind regards,
Steve
The trigger in the handle moves a spool valve. The operator can 'feather' the trigger to start slowly. Otherwise, the tool is run at full speed. The valve type is open-center. When 'off' flow is bypassed to return.
Ted
Ted
Have you considered having the surface tender dialling down the speed until the hole is started and then going to full speed?
Bill
"Why not the best?"
Jimmy Carter
If you were to put two spool valves in parallel, with one set to trigger a few millimetres earlier than the other and with its flow throttled through an orifice, you could get some very tidy two-speed control - but that would force a move to closed-centre valves with a compensator package - and your costs and weight would start to get uncomfortable.
A.
Put a T-handle arrangement on the drill motor. Might be better for torque reaction control. A T-handle with a trigger could be made to operate a spool valve if a two-man operation is not desirable.
In my former life I used to design tools like this.
Ted
That's possible (especially since this discussion is happening on the Engineers with Hobbies forum) - but if it's being done in the context of "Diving at Work", then it's more likely that one diver will be working on his own on comms, with the standby sitting in the wind and rain getting bored on the surface.
Torque reaction control is bothering me a bit too - kind of an extension of my worry about how the diver is going to manage the hoses. We don't know what the task is and whether it's something that can be done while solidly weighted onto the bottom - but it might make a good spectator sport, if only there were a little visibility.
A.
There will normally just be one diver in the water with the stand-by man ready to go. The comms system would easily allow for voice control orders between diver and surface but I foresee the initial start-up of the drill being the biggest issue where there might be fine tuning of the start and speed control required. I'm beginning to think an on-off flow valve affixed to the drill, with a flow controller at the power pack (adjusted by the dive supervisor) might be the solution.
I am not concerned about the torque reaction as I am only drilling 6-8mm holes in reinforced concrete.
I would hate to see my diver spinning around like windmill sails.
Edit: A two-port valve could be used for on-off by plumbing it between the pressure and return lines.
Ted
One finger on the trigger to control the speed is about it.
You may find that the best solution is to have the surface man control both speed and on-off.
How thick are your diver's gloves? The gloves that we wear on the surface at minus 20 degrees make controlling a hammer drill a little clumsy.
Bill
"Why not the best?"
Jimmy Carter
