AISC Steel Database XML
Would anyone know where I could find the AISC steel tables in an xml format. I am working on some in-house software.
RE: AISC Steel Database XML
Go to the AISC website, "www.aisc.org", then look for the Publications page of the website. Then go to the Steel Construction Manual page. When you get there you can download the Shapes Database in an excel format. Then open it in Excel and save it in an "xml" format.
Jim H
I wish it were that simple.
If you combine "wannabeSE's" directions with the tables from the AISC ".xls" file you might get tables that could be substituted into the software. You will need to give a more complete idea of what you want to do before anybody can add more helpful suggestion.
Jim H
