F1554 high strenght anchor bolts (capacity table)
Does anyone know of a table I can reference to get tensile capacity for a given anchor diameter? Specifically, I'm looking for F1554 (36, 55, 105) anchor bolts for a high uplift load.
Thanks!
Thanks!
RE: F1554 high strenght anchor bolts (capacity table)
Strength of the steel bolt itself can come from ACI 318 or various other design codes.
Strength of embedment would typically come from ACI 318 and would depending on the bolt and concrete details, not easily put into a table.
In addition to bolt size varying, threading can vary, which has some effect on bolt area.
But see http://www.portlandbolt.com/technical/thread-pitch... for example, for thread areas.
