bApostropheChrs - Macro to deploy correct CATIA search query syntax
Hello all!
I use V5R20, and the search function, while powerful, uses different query formatting depending on which characters are in the search string. The bApostropheChrs was made through trial and error through all ASCII characters, seeing which ones CATIA surrounded with double quotations (""), and which ones it didn't.
I didn't build a function to use bApostropheChrs (it'd be very simple if you're inclined), but my reusable code snippet is included below!
Hope this helps anyone looking to use the search function more easily in VBA!
CODE --> VBA
' Mod       : Reusable Search snippet
' Author    : Sameh Khan
' Date      : 03.06.2016
' Purpose   : Calls bApostropheChrs to ascertain which query syntax to use, then deploys
'           : based on result.
If bApostropheChrs(ItemName) = True Then
   Call oSel.Search("InitialSearchQuery" & Chr(39) & ItemName & Chr(39) & "Scope")
Else
   Call oSel.Search("InitialSearchQuery" & ItemName & "Scope")
End If
CODE --> VBA
Function bApostropheChrs(str As String) As Boolean
' Function  : bApostropheChrs
' Date      : 03.06.2016
' Purpose   : Ascertains whether the search string includes a character that causes
'           : CATIA to change it's query syntax to include double quotations.
'           : Returns TRUE if quotation marks are needed in Search query.
    Dim strApostropheCharSet(12) As String 'Charset that requires a different Search query structure
    Dim i As Integer
    strApostropheCharSet(1) = " "
    strApostropheCharSet(2) = "&"
    strApostropheCharSet(3) = "("
    strApostropheCharSet(4) = ")"
    strApostropheCharSet(5) = "+"
    strApostropheCharSet(6) = ","
    strApostropheCharSet(7) = "-"
    strApostropheCharSet(8) = "."
    strApostropheCharSet(9) = ";"
    strApostropheCharSet(10) = "<"
    strApostropheCharSet(11) = "="
    strApostropheCharSet(0) = ">"
    For i = LBound(strApostropheCharSet) To UBound(strApostropheCharSet)
        If InStr(str, strApostropheCharSet(i)) > 0 Then
            bApostropheChrs = True
            Exit For
        End If
    Next
End Function
Have an excellent Christmas! santa
"Simplicity is the ultimate sophistication." ~ Leonardo Da Vinci
