Overcurrent Protection Coordination with Delta/wye Bank
What is the best practice for sensing low side bus ground faults on a Delta-wye transformer with high side protection? Since a L-G fault on the low-side appears as a L-L fault on the high side, the phase overcurrent elements must react to this fault. If the transformer is on the larger side or has a high impedance, it becomes difficult to set the high side phase overcurrent elements at a level that allows for maximum transformer loading, but also still reacts to L-G faults on the low side of the transformer in a reasonable time span.
RE: Overcurrent Protection Coordination with Delta/wye Bank
"Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic ù and this we know it is, for certain ù then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature". û Nikola Tesla
