Rate of Evaporation from an UG CMP detention system
If I have an existing UG CMP detention system that is holding water with no methods of routing or infiltration till 3/4 full. I was wondering what the rate of evaporation from this UG CMP detention system is there some sort of a calculation to estimate the evaporation from this underground detention system?
RE: Rate of Evaporation from an UG CMP detention system
You would probably get some leakage over time, the amount of which depends on how it is constructed.
