which is the best coating to avoid corrosion in electric towers?
Hi there,
Im working in an important electric transmission company in South América.
We are actually having some corrosion issues in our electric towers in C5-I and C5-M zones, and i am looking for the best coatings in order to prevent the corrosion and to reduce the maintenance of the towers as much as we can.
C5-I: Very High - Industry: Industrial areas with high humidity and aggressive atmosphere
C5-M: Very High - Marine: Coastal and offshore areas with high salinity
Which coatings do you recomend to protect transmision towers exposed to those conditions?
Thanks!
Thanks!
RE: which is the best coating to avoid corrosion in electric towers?
In the document take a look to numerals 2.1.7 thru 2.1.10 on pages 6 and 7, and numeral 2.4 on page 8. I hope it can help you. https://micanaldepanama.com/wp-content/uploads/201...
El que no puede andar, se sienta.
Do you also use EN1090, and/or EN ISO 1461 ?
If not, they may be helpful in your case.
http://www.fusionpoint.be
http://be.linkedin.com/in/fusionpoint
