projection of points from a sketch to a sketch
Hi there
I would like to know if it is possible to project some points from a 2D sketch to a new 2D sketch (the are perpendicular located each other) or another way i could handle is to snap some circles to from one sketch to the points that are created in the first one.
I assume that the points are construction geometry and can not be projected, i tried to convert them to active elements but i think is not posible
i am attaching a capture with the data
Thanks for your help
