Soldering Surface Mount Components
I know most boards are now put together by robot but is there an elegant way to solder surface mount components by hand?
Special solder or flux?
I'm just referring to chips with a low connection count, typical 3 maximum of 8
Roy
Roy
RE: Soldering Surface Mount Components
TTFN (ta ta for now)
Lacking that, well, I have ways I do it that work with experience. A blunt tip, fresh de-solder wick, and good tweezers. Tack an IC down by one lead. Use tweezers to align as you re-heat the lead. Tack the corner pins. Have a go at the middle pins. Then use the de-solder wick to remove all of your mistakes taking care to only remove the majority of the solder with the wick.
Dan - Owner
http://www.Hi-TecDesigns.com
Was a royal pain.
Roy, I'll solder them for you if it gets to be too big a hassle.
Keith Cress
Keith Cress
Dan - Owner
Keith Cress
I just looked... when zoomed in fully using the scope on my desk, four quad-resistor packs (0804) sitting end to end barely fit the field of view. The scopes on the soldering benches are even high magnification. Our soldering tips are pretty fine, so there's still plenty of viewing area, even with an 0201.
Dan - Owner
If I have a lot to do or any pads that aren't accessible I'll get a stencil from Polulu for about $50, squeegee some solder paste through it, then place components and put it in toaster oven.
Cheap stencils:
https://www.pololu.com/product/446
Oven that doesn't require mods:
http://www.bestbuy.ca/en-CA/product/panasonic-pana...
Try this place. I've ordered one from here at 3am and had it shipped at 5am. Blew my mind.
ohararp stencils
$25 - Highly recommended.
I get the Kapton ones. They last quite well. I've gotten Kapton ones to do a first few protos and ended up not needing any revs, and gone on to make a couple hundred boards with them.
Keith Cress
Dan - Owner
Keith Cress
Dan - Owner
MacGyver, I use an oven similar to the one in the link and change temperature manually about once a minute. A controller and insulation would be a nice addition.
Dan you can use any old clapped-out toaster oven that is 1400W or so and has top AND bottom elements. You will want one with a single shelf that slides in and out without any herky-jerky. Throw away the rest of the shelves.
You will likely need to hack it to remove all signs of temp control. Wire it up so you plug it in and it heats up.
Then use something like this stuff:
McMaster Carr Semi-rigid insulation
to insulate the top, sides and back. Often the bottom doesn't matter much.
Grab a ramp-and-soak temp controller or use an Automation Direct cheap CLICK PLC with a TC module and a relay of some sort. Cycles are so mellow you can use a mech relay without issues.
You want a small gauge TC too. I use these:
24AWG or smaller Type J or K
You place the TC directly on one of the boards you're reflowing. You put it on a bare pad somewhere so it is measuring the actual board pad temps. You need it coming in from above so you can slide in the shelf with the boards then lift and set down, very much like a phonograph needle, the TC onto the selected board. You want the TC stiff enough to stay but not wrestling-match stiff so when you let go it sweeps across your parts going to where it wants to be.. (Been there.)
Then setting the control profile you typically have some initial long PWM to get the board up to about 80/90C and then dwell there for moisture reduction. Then more aggressive PWMing to get to about 80% of the melting point and once settled there you do a full-on bust-a-gut sprint up to the peak temp in about 30 seconds. (that's where you need the power and low heat loss). Then power down and let the whole thing cool down to just below the freezing point then you need to open the oven door about 30% to get the temp down pretty quick or you roast all your parts and the boards lose their flatness.
A PLC might make the most sense since no normal Ramp-and-soak deals well with the second based times and the fact that the oven will be fire-walled often to make the schedules. You will end up setting the Ramp and Soak to ridiculous values that will be changed before ever reaching them just to get close to the desired profile. A PLC could also open the door for you in a timely manner.. I've not noticed and 'browned' things. A PLC also could BEEP you that the cycle is over since you do NOT want this thing out-gassing in the same room you're in.
Oh OH You definitely want an oven with a see thru glass window as you'll need to watch the process frequently to troubleshoot and tweak.
Keith Cress
http://www.whizoo.com/reflowoven
Dan - Owner
Keith Cress
Dan - Owner
Putting a servo in the hot air stream of the opened door seems wrong to me.
btrue; good point but there is really so little thermal mass in a toaster oven that the servo is 'toasted' for only about 2 minutes.
Keith Cress
Dan - Owner
Keith Cress
Feb 16: received email from ohararp saying it "was" shipped on Feb 17
Feb 20: shipper's tracking info did not say it had been picked up. I emailed ohararp asking for update.
Feb 21: tracking info still doesn't say it's been picked up and still no reply from ohararp.
After writing him saying essentially, 'you normally take a few hours to ship, here it is 15 days.. It appears you did the postage but never actually shipped it!'.
His response was abject apology, refunded all charges, did it again (or for the first time), shipped it priority USPS, and I got it two days later - 5 days after I got the boards..
Apparently he does this as moonlighting and he said his day job sent him off elsewhere for a week, (I gathered this was a first).
Sorry for your and (my) bad experiences.
I told him, "This is a big problem not knowing what the delivery is really going to be. Some jobs don't matter but some are critical, and if we could just know what the turnaround was going to be then we could go elsewhere when pressed for time."
I got no response.
I'll give Pololu a try next time.
Keith Cress
Z
All you need, No lead, water washable.
Keith Cress
I can see where I would need a toaster oven to assemble a board with many components but my boards are single sided probably have about 10 on a board 1-1/2 square.
I have been soldering the surface mount components with just a regular fine tipped iron, typically LEDs or components with no more than 8 legs.
I tin the circuit board first with just a dab of high quality solder then hold the component in contact and just heat each pad with my iron to melt the solder, sometimes melt a dab of solder close to the component leg for good measure.
Crude I know!
Roydm: It's best if you just tin 1 pad per component before placing the component. If you only tin one pad then the component can be pushed down to contact the PCB while heating that 1 pad. That was required in avionic communications equipment for a few reasons:
Less chance of losing electrical conductivity when there is a bad solder joint, ex; cracked or cold.
Less chance of contaminant buildup causing short circuit, ex; dust buildup under floating capacitor.
It can reduce the stress on the component and the solder since the component is supported by the PCB instead of by solder.
Z
If you buy the paste I linked you to DKY will automatically ship it next day with an ice pack in an insulated bag. $$$$$$ painful!!!! After using more than ten of those syringes of paste over a couple of years we've found that if we leave the syringes capped and in the insulated bag with the ice pack when not actively using it. It is completely usable for about 3 months. We see no difference at all. After about three months of summer we start to see separation and it doesn't stencil as cleanly.
We simply try to keep its daily temp cycling to a minimum. If we aren't going to use it for a while we toss the bag into the bottom of a loaded (thermal mass) cabinet to keep it as cool as the office can provide in a place with the lowest likely thermal cycles.
We've actually used it out to probably 6 months.
That said I always, in the "checkout instructions", direct DKY to NOT elevate the shipping for the solder paste. The one time they did anyway a call got them to wipe all shipping charges.
Keith Cress
Thanks, I will try the one pad method.
The solder paste sounds like a royal pain!
Keith Cress
I soldered smt components before,and alot,they made for prototypes,if you planning to do that for a product you sell at the market,then use robot or furnace for production
And yes it needs very skilled technician, even through hole solder may can't solder smd components
It needs heat gun if you solder blga ic's,and heater with very thin tip " the heater equipped with the heat gun is perfect use" if you sold a chip pins on the board surface the solder to be very thin and good quality,
I hope i helped,regards
