Corrosion resistance - AISI 4340 involute spline driveshaft
thread78-38302: Material for drive shafts.
I'm designing a gearbox driveshaft and I'm interested to use AISI 4340 as material.
Is advisable to apply a plating/coating or a thermal treatment in order to improve the corrosion resistance on the spline teeth?
Pierluigi
Pierluigi
RE: Corrosion resistance - AISI 4340 involute spline driveshaft
Use caution when plating this type of material, due to an increased risk of Hydrogen Embrittlement.
