[NX 10] - Import Coloured Point Cloud (points + RGBdata) in Siemens NX 10
Hi, I am a NX10 user. (10.0.3)
I am currently working on a Reverse Engineering task. I need to import the reference data to start a reverse engineering process in Siemens NX 10. My data is a point cloud in .ply format. The cloud, however, has also RGB data associated with each point and I need to import that too.
In other words, I need a coloured point cloud imported in Siemens NX 10, does anyone knows if this is possible and how?
Do you know if it is possible in Siemens NX 11 maybe?
RE: [NX 10] - Import Coloured Point Cloud (points + RGBdata) in Siemens NX 10
www.nxjournaling.com
in NX11 we can import a .pod file as a reference point cloud. This will show also the colors of the scan data.
you can use this POD file to make measurements in and can make clippings from this to hide some areas from the point cloud.
Greats
Ruud van den Brand
NX pre-sales Consultant
cards PLM Solutions B.V.
