Export 2-D Section View Of Model
Greetings:
I have a model of a round part where the contour is unique. I need to section this part and export it into a .dwg file. Can anyone help me with that process?
Brent
Brent
RE: Export 2-D Section View Of Model
- Switch to the drafting module, add a drawing sheet.
- Add a base view of your model.
- Create the desired section view from your base view.
- Use file -> export -> autocad dxf/dwg to export the drawing sheet.
The details of each step may differ slightly depending on the version of NX that you are using.www.nxjournaling.com
Thanks again,
Brent
If this is about size/scale, it will depend on some combination of your sheet scale, view scale, and export options (and possibly the import options of the other system). I don't often have the need to deal with dxf files; years ago, some files that I imported had to be scaled by a factor of 25.4 to account for english/metric unit conversions.
Yes, I'm referring to the scale. I just want to make sure that it when bringing it in to AutoCAD, that the geometry is scaled 1 to 1 (Full). I guess with your explanation above, there might be options to check to ensure it is scaled properly. For example, if in my UG drafting sheet, I brought a view in at 1:2, then when I export that sheet, will the geometry export at 1:2, or just Full?
Thanks again for your time on this question,
Brent
https://docs.plm.automation.siemens.com/tdoc/nx/10...
and I've not played around with it, so I'm not exactly sure what it does.
