Material (PLASTIC) needed
Hello
I am designing a tool holder for a motorcycle, that will come in contact with many chemicals on and around the motorcycle.
I have selected HDPE to manufacture it out of injection moulding.
Is there any other materials (plastic) that I could use.??? smile2smile2
RE: Material (PLASTIC) needed
I would look at glass filled nylons.
Why is that?
Nylon is very resilient. It's considered 'tough'. The glass added to it makes it considerably stronger - same as rock in concrete.
Keith Cress
Okay cheers
Actually I think you could try PP too. It is widely used to produce this kind of box/case in China. ABS is expensive, while PE is not so tough like PP.
Expert of nucleating agents
www.nucleatingagent.com
