O-ring groove too deep - options
We may have a situation where an o-ring groove is so deep the o-ring will not be squeezed at all at installation.0.25" Ø section. Low pressure oil seal.
I think I've seen instances where a second, very small section o-ring was installed first to provide a seal.
I was surprised when I found nothing in all my o-ring information.
Does anyone know of an "official" fix?
RE: O-ring groove too deep - options
You may have to open the with of your o-ring groove.
Or maybe try to cut a thin garlock or similar gasket to drop into the groove and take up some space? Like a backing ring?
The assembly specialist said the o-ring looked barely flush in the groove, and the cover assembled "too easy", kind of confirming the measurement was correct.
Thanks for the suggestions.
The part was assembled and pressure tested fine.
The assembly specialist said the o-ring looked barely flush in the groove, and the cover assembled "too easy", in my mind confirming the "too shallow" measurement was likely correct.
That particular O-ring is not likely to get very cold, very often.
https://c2.staticflickr.com/4/3697/9271989530_b002...
