Safety factor for administrative hypothesis
I've received a pole des project where the client requires the following:
For administrative hypothesis:
A safety factor of 1.8
Wind pressure on the face of the pole: 840 Pa
For extreme wind:
A safety factor of 1.1
Wind pressure on the face of the pole 2050 Pa
My question is, what exactly is it refering to?
Is extreme wind a reference to Ultimate limit states? Or accidental winds?
Is administrative hypotesis refering to Serviceable limit states?
For extreme wind:
RE: Safety factor for administrative hypothesis
http://www.fusionpoint.be
http://be.linkedin.com/in/fusionpoint
With that being said, it sounds like maybe there is a language translation issue here - I could see the "service" in "service loads" being translated as "administrative".
It's been a little while since I worked with ASCE 48, but I don't think the factors of safety mentioned refer to ULS or SLS specifically. Just that they want your structure to resist a "common" wind load with an F.S. of 1.8, and an "extreme" wind load with a F.S. of 1.1.
Never heard of accidental wind.
But all that said -- pick up the phone and ask the client.
The client is Indian, so the language is probably Hindi, and I can't contact him so far.
Edit: I received the data in english language
Anyways thanks for all your help
A SLS that is more burdensome than ULS makes no sense in my opinion. I'll try to contact the client and provide feedback if possible.
If you are designing for strength under both load combinations, then they are both ULS.
To have a frequent ULS with a high load factor being the critical condition, rather than a rarer ULS with a lower load factor, is not at all unusual.
Indeed it is a desirable outcome, where achievable.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Also, the largest wind load will occur when the winds "sees" all 4x guy ropes. There will never be a reasonable case when the central vertical mast "hides" the downstream guy ropes.
I don't think he is talking about a guyed pole...didn't mention guys.
