Newmarks method for implicit dynamic analysis
I have used Newmark's method wherein my damping matrix was generated through a combination of mass and stiffness matrix (Rayleigh damping).
IS it possible to use the Newmark's method if the damping matrix is non diagonal?
Ash
Ash
RE: Newmarks method for implicit dynamic analysis
The matrix formulation isn't too much different from the SDOF formulation, but if you're using Excel it may be a bit painful. If you have access to Matlab or MathCAD, or a free alternative, they should be able to make short work of it.
My go-to text for this is Chopra, third edition, which covers this in Section 15.2. You can also probably find a good online reference fairly easily.
