CATIA V5 R20 SHORTCUT COMMOND SPACE IN NOT TAKEN
RE: CATIA V5 R20 SHORTCUT COMMOND SPACE IN NOT TAKEN
Set ima modification shortcut to something else, or remove the shortcut to ima modification. Then you should be able to set that shortcut to a different command.
