Minimum required relieving rate!
In the calculation of minimum required relieving rate for PSV in a cooling water line, we have to use following equation,
q = (alphav*phi)/(1000*d*c) [API Standard 521; Section 5.14.3]
But I don't get how the unit of q comes in m3/s.
Require help in this matter!
Shiplu48
RE: Minimum required relieving rate!
Please attach your work on the unit conversions, and we'll see if we spot the problem.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
I have mistaken the units. Got it right.
