Hi guys. I've encounter this senten
Hi guys. I've encounter this sentence of shut down of a distillation column. What does it mean "block in"?
"If the system has to be emptied, block in the above mentioned control valves."
RE: Hi guys. I've encounter this senten
It might be defined as a specific action somewhere in the rest of the procedure. Can you do a text search?
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Since this may involve a safety issue, you should put the question to the original designer.
