Disable or hide NX "Aids" and "Popups"
Hi people.
Please, does anybody knows if there anyway on earth to disable, hide and/or desactivate the "Aids / Popups" that are circled in red on the attached picture.
On the left is the "Aid" that is displayed using Studio Spline, on the right is the Popup that appears when you select objects.
I imagine they can be usefull for some people, but for me the are completely useless, not to say annoying.
I currently use NX 8.5 and NX 10
Any help or idea are very much appreciated.
Thank you guys, very much in advance.
RE: Disable or hide NX "Aids" and "Popups"
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
I agree with John
Any way the left is not removable
And the right could be removable with tools/customize
Didier Psaltopoulos
http://www.psi-cad.fr
First of all, thank you for your promptly reply.
I design and manufacture alluminium stamps for hot stamping process. Most of forms that my clients ask me are organic forms. There are few ocasions where I need to lock an axis or lock a plane on studio spline.
The main problem with Studio Spline "Aid" for me is that every time I reposition (pan) the screen, the aid appears again on center of the screen, and in my case, 90% of time it appears very near, or over the spline pole, so I have to drag the aid away from the poles over and over again, literaly several hundred of times on a typical work day.
In my opinion, since we have all the same commands on the Studio Spline Window, under group "Movement" I think that it would not hurt to have a check box to simply show/hide this aid.
I completely understand what John said: "If you started to use them for their intended purpose your opinion of them would change.", but that is not my case. I know is purpose. Not everytime a solution that is good for an industry is also good for another one. ;)
@DidierPSICAD or @JohnRBaker... Can you please point me where is the option in Tools -> Customize that can disable the popup in the right picture?
Again, thanks a lot in advance.
Irvine, CA
Siemens PLM:
UG/NX Museum:
