Autocad 2000 Redefining Blocks
3
I have tried to redefine a title block by inserting a file, with the same name as the titleblock.  This appears to be partially successful. Although the block appears to change, even when exploded, when I go to edit the attributes, by using the edit block button, in the "edit attribute" window they still maintain the old attribute tags.
Is there a way of updating attribute tags in the "edit attribute" window?
RE: Autocad 2000 Redefining Blocks
3
Dear GavinHarkness,
You should use the REFEDIT command. Keep in mind that you need the commands REFSET and REFCLOSE to save changes and finish the reference editing.
Farzad
