Calculating Bending moments in edge supported plates
I am remote my office and do not have access to Roark. Does anyone have a bending formula for a square plate supported on all four edges with (2) point loads at 1/4 points?
RE: Calculating Bending moments in edge supported plates
I'm sure someone does, but you can always do yield line analysis as another option.
Yield line analysis will provide an upper limit to the actual failure load but will not provide an elastic solution; it will not provide elastic stresses or deflections of the plate.
Edit: text in red has been changed
BA
I looked in Roark,7th Edition, and there is no such loading + boundary condition.
I've got a couple of ultra conservative formulas I use for such a situation......but you probably need something more precise.
If prex's sheet doesn't help......I'd be willing to run a few [plates] for you on my software. (I sympathize strongly with being on-site and not having access to tools.)
Using yield line theory, I get P = 6m where P is the value of the point load and m is the yield moment of the plate per unit length. To allow for corner effects, it is usual to take P as 0.9*6m or 5.4m.
BA
