Want Suggestions for Cast Material Suitable for High Temperature Use and Significant Abrasion Resist
There is a ball that is used for form metal in a spinning process which includes hot spinning. Ideal material would have high abrasion resistance, high toughness and suitable for high temperature use (surface temperatures up to ~1300F).
Ball size: 40” OD (39.370” finished OD) x 11.5” ID (11.811” finished ID) x 25” Long (23.622” finished length) Casting, Approximate Weight 7,400 lbs
I've ruled out any castings with significant amounts of chrome (over 0.5%) because it increases brittleness; all ASTM A532 materials.
Any suggestions on material grades that should be considered?
Thank you for your time
A Fan of EngTips, share the knowledge
RE: Want Suggestions for Cast Material Suitable for High Temperature Use and Significant Abrasion Resist
Hadfield steel, a good choice ,will not develop surface hardness, unless subject to impact. May be you can consider preconditioning the material, before use.
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
Also consider hard facing (PTA or laser) with Stellite or WC base coatings.
I'll look into cast Hadfield steels
Maybe I was too quick to rule out castings with significant chrome (ASTM A532). The operating temperature of the ball would definitely be over 600F, because the plan is to pre-heat the ball before hot spinning to reduce the thermal gradient in the ball. The surface temperature of the ball might reach ~1300F or higher (hot spin stainless pieces that are pre-heated to 2150F in a oven)
I'm shying away from Hastelloy material due to cost. That is a great suggestion to look into surface treatments that would create a very abrasion resistant layer on the surface. In the past I was involved in a job where they did high velocity oxy-fuel carbide coating on the surface of part.
I want high surface hardness, hopefully over 600 HB
I'm looking into Austempered Ductile Iron Castings (ASTM A897) as an option. Hardness only reach up to 460 HB (Grade 5).
Honestly for hot hardness either a Cr cast iron or a Co based alloy are your only real options. And the Co alloy will be 10-20 times the price
