Ordinate Dimensions on an Angle (Projected View)
Can anyone explain how to do ordinate dimensioning where the origin axes are not vertical and horizontal? I need to align them with part edges that are rotated 35°CCW. I've found answers in other forums that don't seem to make sense with what I'm seeing. I'm using NX 9.
Thank you,
Matt
Thank you,
Matt
Matt Steenwyk
Mechanical Engineer/Project Lead
Disher
www.disher.com
RE: Ordinate Dimensions on an Angle (Projected View)
if you are looking to rotate the axis of ordinate dimension have you tired specify vector option in Base line group.
Ram K
NX 9,TeamCenter
Mechanical Design
I have tried that several different ways but I haven't gotten it to work so I must be doing it incorrectly. No matter what I do, as far as I can tell, the vectors stay horizontal and vertical.
Matt
Matt Steenwyk
Disher
www.disher.com
