EIS physical models
EIS physical models
Hello everyone
I'm looking for a matching physical model to the graphs I got from EIS of reinforced bar in concrete.
The cube of poroeus concrete (150x150mm) with the bar of common reinforcment steel in the middle positioned vertically is fully covered by 1M NaCl solution. The rebar is connected to the circuit by a steel wire that is also in contact with liquid medium.
It's pretty hard to find matching model, even, when I might have a clue what's happening in evaluated material.
Models proposed by me, based on my thoughts are not giving me similiar graphs ( in ZSimpWIN -Z"/Z') to those I got from the study of material.
Maybe some of you, much more experianced or with the insight of the problem has an advice for me, or an information about what kind of models others, you, you know they do, are using with success.
I'm new to this kind of problems and I'm doing this study for my thesis as an engineer and the time is running so please :)
By the way, I'm from Poland, University of Technology in Gdańsk. :) Maybe that'll help :P
RE: EIS physical models
TTFN (ta ta for now)
