VBA using Excel (If Statement) please help!!!
I need help
I am trying to make an if statment that deletes the entire row if a cell's value in that row is less than 100.
Example: I have a list of people with all sorts of information on them in separate columns, age is one of the columns.  I want to delete the person or row if that person is, lets say, under the age of 100.
RE: VBA using Excel (If Statement) please help!!!
Put a command button on the sheet and use something like:
Private Sub CommandButton1_Click()
Dim myrange As Range
Dim myrange2 As Range
Dim rowcounter As Long
Set myrange = Worksheets("Sheet1").Range("A1:c100")
For rowcounter = 100 To 1 Step -1
    If myrange.Cells(rowcounter, 2).Value > 50 Then
        Set myrange2 = myrange.EntireRow(rowcounter)
        myrange2.Delete
    End If
Next
End Sub
Where the 2 is the column you are testing
aordoqui,
Did it work OK for you?
