Machining deflection
Is anyone aware of an anayltical method to estimate tool induced deflection when turning a relatively thin walled cylinder on a vertical lathe? I'm aware I could use FEA or similar software to solve my problem for me but it seems a simple enough problem that there must be a first principles way to get a quick estimate. Roark's wasn't forthcoming with an answer
The cylinder will be ridgidly clamped on a rotary table at the bottom end and unconstrained at the top end where machining will take place. A bracing fixture is being considered to oppose any deflection but I'm not convinced, and neither are many others here, that the component will deflect significantly. However, I can't rely on such non-scientific guessing to say "it will be fine", and I don't fancy spending a chunk of cash on a fixture I might not really need.
RE: Machining deflection
If you examine & study chip-formation theory and the equations developed from that theory which are used to analyze machining processes, you will see that tool-induced forces apply to shearing off a thin layer of material and making chips. I would think that forces are primarily used to make those chips because that is where the weakest point will be: shearing off a chip along a shear plane and not deflecting the bulk material through bending. This applies to proper machining conditions for your work (speed, feed, depth of cut). Go outside those "normal" parameters for your part and, sure, I suspect that you'll deflect the heck out of it. Wear your face-protection shield and stand back when you do because it may get momentarily exciting.
At the micro level of thought, minimal cutting conditions would (I suspect) produce some deflections in the part, but those deflections would (I suspect) be less than your measuring instrument tolerance and you'd never see them.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
A Google search found this:
http://www.kennametal.com/en/resources/engineering...
http://todaysmachiningworld.com/magazine/how-it-wo...
Static deflection might not be much, but if you get a match for the natural frequency you'll make garbage out of the workpiece and maybe the cutting tool as well.
Ornerynorsk - 2m diameter, 2m length (ish) nickel-chromium-iron alloy with a 20mm or so wall thickness.
Parts used to be made on a horizontal borer and sagged into a slight oval under their own weight - ended up being machined in that deformed shape, recieving a circular cut and relaxing to an oval bore when stood upright again.
They are being cut vertically this time to stop that but it doesn't change the fact they are not really that rigid.
I'm curious, is the machining to be done on the ID, OD, or end face, and I'm assuming it has a weld seam?
The workpiece proportions are not a whole lot different from those of a common steel drum, but without the reinforcing ring ribs.
I submit that you may need to insert a diaphragm near the top end while machining it; I'm thinking something like the end of a whisky barrel, made from >100m thick timber, jammed in or made with some expandable features, like peripheral elements expanded by driven wedges.
You've got room to frame a big door in the diaphragm, include columns to support it while it's being tightened, and stairs down to access the faceplate inside the cylinder for securing the bottom end.
Mike Halloran
Pembroke Pines, FL, USA
