Distance between RD and PSV
Is there any regulations regarding the distance of rupture disc installation with PRV?
One information that I have found is "it should be closed coupled (1-2 feet)". But I don't know where does it come from, ASME or API?
According to this rule distance between PRV and RD should be greater than 2 feet.
Any recommendation is highly appreciated.
Many Thanks.
RE: Distance between RD and PSV
I recommend reading studying section 4.3, titled Rupture Disk Devices, in API 520 Part I. If you have further questions after that, come back.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
