Electric Duct Heater size
HI guys one question..I have a Electric Duct heater (EDH)..the capacity of the heater as per design is 0.6 KW..the flow in duct is 60 l/s. However the supplier are able to provide only 0.85 KW. What is the solution to use this duct heater?
RE: Electric Duct Heater size
what is the application? is it acceptable to have air overheat a bit, then cycle off to be too cool and overheat again? It is common to not always find an exact match, they don't make equipment in 1% capacity increments.
Well there is only Solid state relay controller..i will check the contract again..and revert tomorrow
