hardware key
hardware key
hardware key
Cutler-Hammer D-100 need physical hardware key on parallel port, any idea what's in connector?
RE: hardware key
Yes it does.  I took one apart several years ago and if I remember correctly it had a chip of some sort and a couple of resisters.
RE: hardware key
The Ic-s behavior can not be determined by test during the lifetime of the universe.
A combinatorial logic with N inputs may have 2^(2^N)
possible states. Any bit of memory is equivalent to
an input so N = number of (inputs + memorybits )
A 1Kbit memory will have two to the
1.27x 1,000,000,000,000,000,000,000,000,000,000 possibilities.
There is one way: autopsy the chip and measure under
microscope with micromanipulator -- a major project.
<nbucska@pcperipherals.com>
RE: hardware key
Some people's kids.... P-)
RE: hardware key
Sorry, an error: The 1.27e30 is the EXPONENT of 2
-- so I slightly nderestimated the complexity...
