NX9 - MEASURE BODIES / SOLID DENSITY
Quite often I have solid bodies that are not correct on the insides because it doesnt matter. I cannot add a material and get a correct weight, but I do know what the weight is supposed to be. The only way I know to get the weight correct is to keep playing with the Solid Density until I get the mass correct.
Is there a way to select a solid body and give it a specific mass and the solid density will adjust accordingly? I do need this body to be correct when doing a Measure Bodies. It cant just have a mass attribute given to it.
RE: NX9 - MEASURE BODIES / SOLID DENSITY
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
I dont know if that is what you are talking about or not. I have never heard of Advanced Assemblies and nothing comes up with that name in a search.
Irvine, CA
Siemens PLM:
UG/NX Museum:
I do see where Weight Management has a check box for "Use Spreadsheet", but I am not seeing how to make that work for a single file with multiple bodies and no components.
Irvine, CA
Siemens PLM:
UG/NX Museum:
If you search for weight management, the sub dialog has a button Assert Values : work part where you can assign weight, area, COG etc
The part family option is only mass ( not COG)
It's assigned to the part , not the body.
IF you include asserted mass in your assembly, you need to calculate the assembly using the weight management dialog. The "measure bodies" does not include asserted values. ( for some un-known reason...)
Tomas
A) Assign Materials - Which will automatically go by the solid body and will come out wrong if the inner working parts of the body are not designed right. Make a Shotpin and leave the cylinder as solid and the mass ends up extremely high.
B) Edit the Solid Density - Which is to just take a basic guess and work from there until you get the Mass to come out right. Edit the Solid Density, check the Measure Bodies mass, change the density check the mass, edit the density... etc
If there is a suggestion box we can use, put me in for a UG Function that you actually enter the MASS and it changes the solid density to what it needs to be for that mass.
Measure the body to find the volume then divide the desired mass by the body's volume to find the density value that would result in the desired mass. Assign that value as the solid's density. No guess work required.
www.nxjournaling.com
You know the weight but still want to calculate it ?
There is something enforcing you to use the measure bodies instead of the weight management ?
( provided you have that license.)
Yes , there is another calculation option in the weight management dialog, which includes asserted values. Including COG.
Tomas
1) Of around 100 people in the company, I would be surprised if more than 5 are even aware of the Weight Management way. Everyone has always been taught by the others to simply do a Measure Bodies. No matter how much I push for it, there are going to be those who continue to do it the old way. When it comes to teaching new tricks, old dogs have nothing on old engineers.
2) Weight Management seems to be great for checking the weights to assemblies and components and work files. When modeling with solid bodies and designing a large end effector that has many bodies and needs to stay within a specific weight limit, the designers are not going to have details to check the weights to. They will have multiple solid bodies and are not going to turn them into details until after the end effector is right and under the weight limit. They wont want to make the bodies into details and then find out they need to redesign it all. So they will continue to do measure bodies.
3) When making family parts with a lot of solid bodies in them, I often will get someone complaining to me that this component or that component is coming out with the wrong weight. Usually because I forgot to adjust that to the bodies. The Weight management way would be great and easy for me to make these family parts, but then when they add the components to their tools and do their measure bodies, they get a different number all together.
At least this is how it works the way I am understanding it.
It looks like I will either have to do it the hard way of changing the density or get a group of old designers to change how they do things. I am betting I lose this fight. But Cowski's math trick will save me a lot of trouble I think. Cant wait to get back to that.
What is an Effector ?
Tomas
Irvine, CA
Siemens PLM:
UG/NX Museum:
I guess there is a chance I am doing something wrong, but Toost seems to have faced the same problem.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Perhaps I am not interpreting this correctly (details = components?), but it sounds like they are using a top-down approach where they start with a bunch of bodies in a part file and break them out into components later. I'm not sure that asserting weights via weight management would work in this scenario.
John - After creating the family parts, I went into a completely different file and added one of the family members through ADD COMPONENT. When I did the Measure Bodies, I selected it off the screen. The problem I believe is that in Measure Bodies, it selects the solid body of the component and not the component itself. When asserting the weights through Weight Management, it adds the weight to the component and not the solid body. I would be great if I could use Weight Management and add the weight to the body as well, but it doesnt seem to work that way.
Irvine, CA
Siemens PLM:
UG/NX Museum:
If anyone finds that can you please take a snippit of the box and post it for me?
Measure Bodies - Volume = mm3
Mass = KG
Density = Lbs/Inch
Why we use these I do not know. I found the formula to be... Density = ((mass*1000)/(volume/1000))*.0361273
Just in case someone uses the same settings as we do and needs to convert.
Thanks Cowski. Saves a lot of time knowing this.
Am I misunderstanding what you mean?
Yes.
There is no need to change your current settings. When you create an expression, you can choose the dimensionality and units for that particular expression. When you assign units to an expression, NX can convert between unit systems for you or warn you if the units you are using are inconsistent with your entered formula (usually due to a user entry error in the formula).
Sorry for not catching on to this faster. I have been wracking my brains trying to learn VBA code lately and feeling lost over it, and simpler things seem to fly past my grasp because of it lately.
The expression system could calculate the density value that you need to assign; I don't know of a way to associatively tie an expression value to the density of a solid body in the file.
Irvine, CA
Siemens PLM:
UG/NX Museum:
