View not show full part in drawing
I made a change to the model and updated the drawing and part of the view is not showing up. I've attached a picture. It's a section of a bolt and the bottom part of the head is not showing up. The section line is running completely through the part. Does anybody have any ideas at of what is happening here?
RE: View not show full part in drawing
I would first try moving the end of the section line closest to the fastener to see if that resulted in an update which resulted in what you're expecting.
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
Does the fastener interfere with some other solid ?
Can you replicate the error in a new file ?
Tomas
www.nxjournaling.com
