Add slabs on ETABS
Add slabs on ETABS
As same on subject "add slabs on ETABS", i make two model with same geometry 9m x 9m with column each 4.5m one story, the different is i add slab full one panel 9m x 9m and 4.5m x 4.5m (4 panels )for second's model. The result is moment almost double for second's model. Which one is correct. need Help and Advice
RE: Add slabs on ETABS
