CATIA V5 R18 Component replacement Macro
Hello Guys,
Can any of you please help me in creating a Macro, which will replace all the parts/components from the assembly.
Presently I am working on CATIA V5 R18 Assembly which consists of dummy components stored in a separate folder.
I have to manually select each part/component and replace it with newly created part which is stored in another location.
This is consuming most of my day's work as I have to replace around 100-150 parts.
So I need a macro which will replace all the parts (or selected parts) in the assembly to that of newly stored parts in different location.
I am not concerned about Constrains. The new parts will occupy the same location as replaced.
Please help me out.
Please help me out.
RE: CATIA V5 R18 Component replacement Macro
like replace folder A\Part 1 with Folder B\Part 1 or the name of the part also change?
by the way it is time to upgrade from R18...
Yes, the file names are same in both Folder A & B.
Thank you for quick response.
