Text Profile based on variable string
Hi there,
I would like to base a Text Profile on a variable string (from the Variable Table in the part).
My aim is to generate a Family of Parts with a custom name engraved on each member.
1. Is there any way to define a character string variable in the Variable table?
2. If so, is there a special code option when entering in the Text Profile field to access this string? (e.g. similar to Property Text codes in draft callouts...)
Regards, MT
Regards, MT
RE: Text Profile based on variable string
http://community.plm.automation.siemens.com/t5/Sol...
There is an existing Enhancement Request (ER) requesting this functionality. You should contact either your local GTAC support or Partner support and request for an ER and to be appended to the existing ER.
http://about.me/davidmerritt
