Digital Pressure Gauge
Hello everybody, we need to below pressure gauge, please inform me your best offer in ASAP, Brands? Models?
Digital Pressure Gauge with Following Specifications:
1)Pressure Range: 0-400 Barg or 6000 psi
2)Accuracy: 0.01-0.025 % F.S
3)Case Material: SS316
4)Wetted Part Material: Inconel 625 or Hastelloy
5)Mounting Connection: 1/2“ NPT
6)Temperature Range: 0-80 C
7)No. of digits of displayer: 2 decimal digits
To be used on sour gas condensate with 5000 PPM H2S and having chloride and co2 .
RE: Digital Pressure Gauge
As an alternative to a digital pressure gauge compare it with the cost of a pressure transmitter with integral display, you might find it cheaper, especially if you need to measure differential pressure.
It's not mandatory to use the 4 - 20 mA signal if you don't need it, just supply it from any simple power supply 12 - 30 Volts.
