LPG fuel vehicle
LPG fuel vehicle
i would like to do quality assurance jobs for (LPG FUEL SYS install in vehicle) , so i want the standards describing the specification of equipments , procedure of installation , testing and final inspection
RE: LPG fuel vehicle
In the copy I have (not current) NFPA 58 includes in Chapter 8 starting with Chapter 8-2 "General Purpose Vehicle Engines Fueled by LP-Gas"
Covers LP general and additional for vehicle container requirements, inspection and re qualification, container appurtenances (valve and fitting requirements), carburetion equipment, vaporizers, piping, installation of containers and appurtenances (location with respect to vehicle structure, static loading requirements for container mountings, markings, road clearance, etc.
US DOT and ASME codes are cited for LP container requirements specific to vehicle use and installation.
The Propane Education and Research Council provides some extensive training material on LP powered vehicle installations:
Quote from their document:
The purpose of this course is not to teach the user how to convert a vehicle to propane, but to enable the user to compare the basic code requirements with other technologies and installation practices and use them as appropriate.
At the time of this publication in the United States, the nationally recognized standards for vehicle conversions are found in National Fire Protection Association manual 58, Liquefied Petroleum Gas Code (NFPA 58). Some states have adopted additional or different code requirements. Users should check with the authority having jurisdiction in their areas to determine which requirements apply.
Additional references:
CAN/CSA-B. 149.5, Canadian Installation Code for Propane Fuel Systems and Tanks on Highway Vehicles
EN67, the European standard for vehicles converted to LP gas
NOTE: Canadian or European conversion standards are referenced to demonstrate that other options are
available and practiced worldwide. It is the installer’s responsibility to determine the appropriate practice
to use for each individual installation.
End of Quote
http://www.propane.com/uploadedFiles/Propane/On_Ro...
but i cant find EN67 , in web
