cooling system
cooling system
Hi everyone,
I am trying to design a cooling system, which contains a big container inside it static fluid, and I have to design pipes go through the big container,the pipes should have cold liquid inside it and this liquid has velocity, I know for the pipes I have to use the following formula:
q= m*cp*(T1-T2)
My question is how can include the material of the pipe which should be important? because the previous formula involve cp for the liquid only?
MANY THANKS IN ADVANCE.
Amaar
q= m*cp*(T1-T2)
Amaar
RE: cooling system
RE: cooling system
RE: cooling system
Convection is of the form:
q = area*convection_coefficient*delta_temp
Conduction is of the form:
q = area*(thermal_conductivity/thickness)*delta_temp
Your equation:
q = mass*heat_capacity*delta_temp is used to determine the amount of heat to be removed. However, your large container has its own thermal losses, which include a convection-conduction-convection pathway, just like the pipe inside.
TTFN (ta ta for now)
RE: cooling system
RE: cooling system
CR
RE: cooling system
Perhaps just a bit more information is needed.
